Identifying products in the scene tab?
stripe6499_9253833ae8
So, let's suppose you have a substantial Daz library, you create a scene, then revisit it some weeks later. You've been working on a lot of stuff and can't remember where some of the items in the scene are located in your library. Say.. a table, a blouse... something with a generic name in the scene tab. Is there any way of identifying the product in the scene?
Just select the item, go to check its Scene Identification. You can find the exact name or some clue in Compatibility Base, in most cases...95%+
Edit - Object - Scene Id...
But... the prerequisite is that the relevant products were installed by DIM ( products from daz.com) or by Content Wizard ( products from 3rd-parties), since all these info. come from metadata in cms ~
If you directly dumped the product folders into the library, you may only check the field of Scene ID in the dialogue box, vaguely there'll be some clues in data folder...
TY Crosswind
There is a script that will do this (for the Daz store products used, it could be expanded to use other stores you have set up).
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/metadata/list_products_used/start
