Succubus Addon issue
Hello,
I am using the succubus add wings for a character and I am having an issues with the textures. when I do a render the underside of the wings does not render any textures. However, the outside of the wings, the texture looks fine. So am I doing something wrong?
  • nDelphinDelphi Posts: 1,991
    Since no one has answered, perhaps it is due to the render engine you are using? Make sure you are using 3Delight and not iRay (the default).
  • I tried that, and whil it does not look lie a grey mass, its still not right on the underside.
    Post images. How it looks in the viewport and how it looks rendered.
  • HorusRaHorusRa Posts: 1,666
    edited August 2017
    no, they work in IRay. I did a piece with them and they rendered nicely in IRay.
    Post edited by HorusRa on
    HorusRa said:
    no, they work in IRay. I did a piece with them and they rendered perfectly in IRay.
    I am sure they do. Especially if you take the time to edit the materials for iRay. How do we know what is going on with ashuramarsh? He/She might just have lights to high and his render is being washed out, without a rendered image we can't tell. Wihtout any more detailed info no one can help.
  • Well, I'm hoping not to sound condescending, But did you check to make sure you applied textures to the underside of the wing? I don't have the Succubus addons, but some items have two shader zones, so you can make the inside different than the outside...
    edited August 2017
