Tabs overlap
https://imgur.com/a/TqjhTln
I have this issue that keeps annoying me. The display viewport options menu keep geeting hidden under the right tabs. I tried to reset the layout, tried to change it entirely, or choose one of the presets and nothing worked. I appreciate any help
  • Double click on one of the side tabs to make the entire set be hidden to the side. Then close the Render Folder [or whatever it's called, D/S is closed atm here] and close the Shader Mixer tab.
    Just have the "stage" showing. Then unhide the side panels and all should be well.
  • Richard HaseltineRichard Haseltine Posts: 112,183
    You have another pane docked with the Viewport with a minimum size larger than the available space - Shader Mixer is often the problem. Right-click ion that pane's tab and select Close.
