Customizing Clothing
Hello everyone, does anyone know (or maybe you can) someone who can alter an item of clothing to the specifics that I want?  Or even link me to a tutorial on how to alter clothing? Thanks! - Ski
  • May be an idea to give a clue as to what you want
  • skiman44skiman44 Posts: 55
    Looking for this in the attached example. Thanks!
    960 x 720 - 113K
  • Richard HaseltineRichard Haseltine Posts: 111,922
    Note that in general it is not permissible to send a model to others for modificastion, or to have them send an modified version back. However, new textures and morphs are usually OK.
    Thanks for the responses. Is there a way to get ahold of the artists to ask them directly?
  • felisfelis Posts: 6,614
    edited March 2023
    Which clothing is it you are thinking to modify?
    I would think that there are many in shop here (and other places) that resemble what you are after.
    And the images attached are in different styles.
    Post edited by felis on
  • ZyloxZylox Posts: 787
    I couldn't find any exact matches in the store. I did find three swimsuits that are somewhat close, assuming the high cut legs are the most important feature for you.
    https://www.daz3d.com/high-cut-swimwear-for-genesis-8-females
    https://www.daz3d.com/neoprene-swimsuit-for-genesis-3-female-s
    https://www.daz3d.com/monokini-for-genesis-3-female-s
    The beads and front straps of the monokini can be made invisibile by adjusting the opacity cutout or opacity in the surface tab. If you use the 3DL textures, you will need to apply a different shader to the beads in order to make them transparent(or creeate an opacity map).
    You may be able to alter swiimsuits to what you want with opacity maps rather than editing the geometry. Here are some basic tutorials on opacity and opacity maps in IRAY.
    https://www.versluis.com/2020/09/iray-opacity/
    https://turbofuture.com/graphic-design-video/How-to-Make-Custom-MATs-for-DAZ-Studio
    https://sharecg.com/v/96709/browse/3/PDF-Tutorial/Creating-Transparency-Maps-for-DAZ-Using-GIMP
    If you have the money and desire to learn, here are some tutorials from the store which may be helpful.
    https://www.daz3d.com/daz-studio-content-creation-mastery-bundle - currently on my wishlist
    https://www.daz3d.com/the-ultimate-guide-to-creating-complex-outfits-bundle
    https://www.daz3d.com/the-complete-guide-to-texturing-clothing-bundle
    Good luck and I hope this helps.
    THANK YOU-THANK YOU-THANK YOU for the links and amazing advice!! I appreciate it so much, and appreciate your kindness! - Ski
  • StarkdogStarkdog Posts: 176
    Skiman44,
    Would something like this work for you?  Even though it is a halter-top style, I have the base mesh to make it into a "tank-top" style.  Also, which model is this for G3F, G8F, G9F?  I currently have a freebie tank-thong style suit for G3F and G8F over at Renderosity, as shown in the smaller renders.
    Thanks,
    David
    1392 x 872 - 71K
    350 x 350 - 97K
    300 x 350 - 44K
    Here is another example base mesh closer to the picture of the black and white swimsuit.  I can leave the "armholes" large or tighten them up to sit more towards the armpit.  Let me know what works for you.  I've modeled this around G3F, but can make this work with G8F and G9F too.
    Thanks,
    David
    1397 x 873 - 74K
    Awesome! Thank you so much for the help! The outfit in the second example looks awesome just the way it is. It's for a G8.1 figure. Let me know what you want for it. And what is your name on Renderosity, I would love to support you - Ski
    Well, an update.  The model is done, but UV mapping in both Hexagon and Blender is jacked at the time, as shown below.  I brought the mesh into D|S, did the transfer utility, and saved as a wardrobe item.  I fit it to both G3F and G8F, and put them through some rather radical poses.  Most work ok, but there is some crotch distortion with extreme bends, which is expected.  I'll push this out as a simple freebie, but re-launch it with proper morphs, JCM, etc.  I also added the base "Lycra" type IRAY shader I have from the first Swimsuit freebie.
    Thanks,
    David
    1147 x 825 - 183K
    This is awesome! Seriously incredible work! Thank you so much for all your effort, I owe you a drink...if you drink!! lol - Ski
    Also, and I apologize for my COMPLETE lack of knowledge, how will I pull the swimsuit into my library, and where do I save it to?  I'm really bad at the technical stuff, thanks! - Ski
    Hi Skiman44,
    Here is a "workable" edition.  It is for G3F, but will auto-fit G8F.  The UV map is twisted, and I haven't added in any JCM morphs yet, but do have dForce, so it "should" work for now.  I have a base Lycra/Spansex shader in place, so the cloth, leg, arm, and neck/chest band surfaces can be color changed as you wish.  I will re-work this into a more feasible outfit, and re-release when it's ready.  As for where to place the items, I have them organized by folder/directory in the zip file.  Please let me know what you think.
    zip
    zip
    G3FTankThong2.zip
    476K
    1000 x 800 - 617K
