Daz Studio: Errors Loading Plugins
lachilachi Posts: 102
So after having other problems I did look into the log of Daz Studio and there are plenty of errors while loading Plugins.
First it says [WARNING] but later on the line it says [ERROR]
Can I ignore those?
Edit: And why does the forum mess up the display of the code block below?
2023-03-15 13:46:19.851 [INFO] Iray :: Loading Plugins...2023-03-15 13:46:19.851 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\aix.dll".2023-03-15 13:46:19.853 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\avcodec-58.dll".2023-03-15 13:46:19.853 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [ERROR] - PLUG:PLUGIN ::   0.0   PLUG   plug error: Library D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\avcodec-58.dll: symbol "mi_plugin_factory" not found.2023-03-15 13:46:19.854 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\avfilter-7.dll".2023-03-15 13:46:19.854 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [ERROR] - PLUG:PLUGIN ::   0.0   PLUG   plug error: Library D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\avfilter-7.dll: symbol "mi_plugin_factory" not found.2023-03-15 13:46:19.855 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\avformat-58.dll".2023-03-15 13:46:19.855 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [ERROR] - PLUG:PLUGIN ::   0.0   PLUG   plug error: Library D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\avformat-58.dll: symbol "mi_plugin_factory" not found.2023-03-15 13:46:19.856 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\avutil-56.dll".2023-03-15 13:46:19.856 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [ERROR] - PLUG:PLUGIN ::   0.0   PLUG   plug error: Library D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\avutil-56.dll: symbol "mi_plugin_factory" not found.2023-03-15 13:46:19.859 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\axf_importer.dll".2023-03-15 13:46:19.859 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\AxFDecoding.1.8.1.dll".2023-03-15 13:46:19.859 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [ERROR] - PLUG:PLUGIN ::   0.0   PLUG   plug error: Library D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\AxFDecoding.1.8.1.dll: symbol "mi_plugin_factory" not found.2023-03-15 13:46:19.859 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\blend_render.dll".2023-03-15 13:46:19.860 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\cb_importer.dll".2023-03-15 13:46:19.860 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\ct.dll".2023-03-15 13:46:19.865 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\dds.dll".2023-03-15 13:46:19.866 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\ffmpeg_video_decoder.dll".2023-03-15 13:46:19.867 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\iray_bridge_client.dll".2023-03-15 13:46:19.867 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\iray_bridge_server.dll".2023-03-15 13:46:19.872 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\libiray.dll".2023-03-15 13:46:19.874 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\libirt.dll".2023-03-15 13:46:19.877 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\libnvindex.dll".2023-03-15 13:46:19.877 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [ERROR] - PLUG:PLUGIN ::   0.0   PLUG   plug error: Library D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\libnvindex.dll: symbol "mi_plugin_factory" not found.2023-03-15 13:46:19.878 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\libnvindex_application_layer_application_layer.dll".2023-03-15 13:46:19.878 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [ERROR] - PLUG:PLUGIN ::   0.0   PLUG   plug error: Library D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\libnvindex_application_layer_application_layer.dll: symbol "mi_plugin_factory" not found.2023-03-15 13:46:19.879 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\libnvindex_plugin_openvdb_integration.dll".2023-03-15 13:46:19.879 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [ERROR] - PLUG:PLUGIN ::   0.0   PLUG   plug error: Library D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\libnvindex_plugin_openvdb_integration.dll: symbol "mi_plugin_factory" not found.2023-03-15 13:46:19.879 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\mdl_distiller.dll".2023-03-15 13:46:19.880 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\mi_exporter.dll".2023-03-15 13:46:19.880 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\mi_importer.dll".2023-03-15 13:46:19.881 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\nv_freeimage.dll".2023-03-15 13:46:19.882 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\nvcuvid_video_decoder.dll".2023-03-15 13:46:19.883 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\screen_video.dll".2023-03-15 13:46:19.883 Iray [INFO] - PLUG:PLUGIN ::   0.0   PLUG   plug info : Loaded library "D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\swresample-3.dll".2023-03-15 13:46:19.883 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [ERROR] - PLUG:PLUGIN ::   0.0   PLUG   plug error: Library D:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\libs\iray\swresample-3.dll: symbol "mi_plugin_factory" not found.
Post edited by lachi on
    The forum isn't designed to output code in-line. It's best to attach the log as a text file rather than paste as content.
    Not an expert there but I think that may possibly be down to an iray/material issue. Check to make sure you are running the latest version of Daz Studio and your nVidia drivers are upto-date.
  • Richard HaseltineRichard Haseltine Posts: 111,265
    Code tags used to work, but they have been broken for a while now.
  • lachilachi Posts: 102
    Thanks
    I have the latest Daz Studio and my nVidia drivers are up-to-date too
