mcjCycleFilter 2023 ! IS ONLINE - The Essential Tool For All Daz Studio Animators
mCasualmCasual Posts: 4,607
edited March 2023 in Freebies
mcjCycleFilter is a free Daz Script i wrote back in 2011 and updated the last time in 2020
you can get the 2020 version on my super-safe google-sites site
LINK : https://sites.google.com/site/mcasualsdazscripts10/mcjcyclefilter2023
the old version which will be improved very soon https://sites.google.com/site/mcasualsdazscripts/mcjcyclefilter
it lets you filter ( low-pass filter ) the animation curves of properties and morphs
i use it for all my walk/dance animation projects
it also lets you scale up and down your curves
and it lets you synthesize animation curves from scratch ( ex: sine, cosine, triangle, ramps, parabolas )
 and it can smothen the curves by averaging your existing curves
while you're at it,
check the other scripts in the script section, dozens of my scripts are related to animation
but there's also dozens of scripts for work on stills
https://sites.google.com/site/mcasualsdazscripts10/home/scripts
paypal donations are optional and very appreciated :)
2066 x 1239 - 1M
2360 x 1640 - 736K
Post edited by mCasual on
  • mCasualmCasual Posts: 4,607
    edited March 2023
    the video from the 2012 release
    edited March 2023
    there's also the SceneGraf plugin and the mcjAutolimb scrip you want to check, no really you do want
    https://sites.google.com/site/mcasualsdazscripts10/home/plugins
    1172 x 759 - 120K
  • Faeryl WomynFaeryl Womyn Posts: 3,779
    I look forward to the new release and that video explained things very well.
    edited March 2023
    been wanting to add S-Curves to mcjCycleFilter many times
    mcjCycleFilter 2023 will have them
    and you'll control how steep the S are
    new Looping VIDYO!
    1532 x 732 - 186K
    1920 x 1080 - 464K
    well since writing programs usually take 3X the initial estimation
    the upgrade will come this week instead of this weekend
    but but I could add the S-Curve-Loop synthesizer to the old mcjCycleFilter tonight
    here you see the S-Curve in action
    it ramps up the S-Curve according to your 'alpha' setting ( between 1 and Infiniti )
    and ramps down using your specified 'beta' value
    https://youtube.com/shorts/AGlRbH9inls
  • tfistfis Posts: 129
    Great!
    Thanks a lot!
    edited March 2023
    Are You Anxiously Awaiting mcjCycleFilter 2023?
    I'm currently writing the user manual for mcjCycleFilter 2023 for Daz Studio
    so in case you know what that's about i was thinkin' maybe you'd like to
    start reading that ( yes there's actually people that read instruction manuals )
    it's also the URL where you will be able to download it!
    as I write the manual I test the script and so far didn't find bugs
    only minor UI things that need to be clearer
    so ... there's chances that it will be downloadable tonite!
    what you see below is the confusing task of mirroring Gabrielle's lForeArm bend on the rForeArm bend ..... 180 degrees out of phase
    1080 x 647 - 112K
    edited March 2023
    Impending Release of mcjCycleFilter 2023
    Doing final checks and bringing back the keyFrame dots that were broken in the 2011 version
    here you see the 4 curves
    CURRENT = red
    SYNTH = green
    FILTER = blue
    DESTIN = cyan
    The user manual is almost complete, i just have to add that there's a ( not too practical ) way to edit the curve using mouse clicks.
    There's no UnDo, i think mcjCycleFilter's UnDo would eat up too much ram, so i won't add that
    then again it only makes as many keyframes as there's frames in your playRange each time you click apply.
    1118 x 670 - 56K
    edited March 2023
    Yay i repaired mcjCycleFilter2023 ( and will repair the old one later ) ability to delete keyframes.
    The mouse-editing will be more precise and therefore usable
    ( I relied on my free sceneGraf plugin for that )
    if you're a daz script writer, functions that return keytimes ( and ticks )
    need to be forced into Numbers by doing for example
    var t = property.getKeyTime( i ) * 1.0;
    ( there's also a .valueOf method but * 1 works )
    784 x 402 - 55K
    It's now online ( posted March 8th around 7:11 PM )
    ( did you know that Robert Plant ( no not Palmer ) once worked from 7 to 11 every night for a while, but it wasn't right and strained his relationship with Baby )
    New Video !
    Animation Loop Created with the help of mcjCycleFilter2023
    and mcjParent, mcjMakeTarget, the sceneGraf plugin, mcjAutolimb2015
    edited March 2023
    i'm fixing mcjCycleFilter (2011/2020)
    and adding new synthesizers to it and the very powahrful mcjCycleFilter2023
    1600 x 800 - 123K
    edited March 2023
    example of using the new animation curve synthesizers that will be included in mcjCycleFilter and mcjCycleFilter2023
    notice the "mirror" and "flip" checkboxes
    ( and mcjStereoMountTool and mcjSimpleVideoMaker )
    1201 x 734 - 271K
    1920 x 1920 - 383K
    Some News about the mcjCycleFilter and mcjCycleFilter2023 upcoming upgrades
    here wou see that mcjCycleFilter will let you work on more than just 1 node.
    you'll get the list of your selected nodes to pick the node
    edited April 2023
    in case the .gif above becomes unaccessible
    here's a slide
    1358 x 761 - 70K
    edited April 2023
    many curve functions will be added
    here it's the staircase function/curve
    1920 x 1080 - 1021K
  • atoxicatoxic Posts: 155
    Thanks
    edited April 2023
    Thanks a lot.
    But w/o undo its difficult to use.
    Post edited by tfis on
     i may add it as an option,
    I didn't include it because i was worried about the memory consumption for storing all the actions done by mcjCycleFilter
    tfis said:
    Thanks a lot.
    before or after posting the updates (it's not ready yet ) for the 2 versions of mcjCycle filter, i'll make a video tutorial where they are used to create walk or dance animations
  • Silver DolphinSilver Dolphin Posts: 1,652
    Very nice thank you.Your stuff is always great!
    edited April 2023
    Thanks, I think i'll make the video tutorial for a Genesis since that's what most people use (i suppose)
    in other news, there's a solar eclipse today
    and there will be a Lunar Eclipse on the next full moon
    well that's not really related to cycle filter but it lets me post an unrelated render in the Forum :)
    or two
    ( Quickly framed using mcjFrameMaker
    https://www.daz3d.com/forums/discussion/599946/mcjframemaker-upgraded-nov-9-frame-your-renders-as-stills-later-as-slideshows
    1600 x 1600 - 2M
    1600 x 1600 - 2M
  • Hey. I know this thread is silent, was wondering if there is any development still going on for the cycle filter? It is a very powerful tool :)
