How to rotate several elements together keeping their distance?
Hello everyone . Maybe someone can help me with this.
I imported an .obj model and it came out in a vertical position to the ground. It is a car model and I want to change the axis of the model but I select everything and it only moves one element. How to make everything together appear with the correct plane position? Thank you very much in advance.
2208 x 1426 - 93K
  • Richard HaseltineRichard Haseltine Posts: 111,721
    In the OBJ import options dialogue try using the 3D Studio max preset, that will adjust the axes for you. OBJ imports are usually single pieces, so I am not sure how you have them independently rotatable.
  • LeanaLeana Posts: 13,583
    edited March 2023
    To rotate a group of objects you could try this:
    1. create a new "null", and position it where you want the centre of rotation
    2. parent all the objects to the null
    3. rotate the null.
    Post edited by Leana on
