G9 Starter Essentials Update?
JOdelJOdel Posts: 6,322
I manually download all of my purchases, and suddenly the G9 starter Essentials is at the top of my product library list. Has there been an update/ Is this something tyhat needs to be removed and reinstalled?
  • I had the same & looked through the readme's in the documentation centre. It looked as if the last update was in December 2022, so there doesn't appear to be a particular reason for it.
    Regards,
    Richard.
  • Calliope23Calliope23 Posts: 546
    I use DAZ Connect, and I also have G9 Starter Essentials at the top of my product library. It says the order was added manually.
  • Same here. It's a bit weird. Putting it at the top of my product library isn't going to make me use it.
    #justsayin'
  • vwranglervwrangler Posts: 5,053
    I think it probably should always have said "manually added" for any existing customers. In any event, I download through DIM, and it hasn't appeared there in the last two days for me. I suspect that may mean that it's a metadata-only update; those don't appear in DIM normally. Those should appear in Connect (which I don't use).
  • ioonrxoonioonrxoon Posts: 896
    There's some issue with it, it keeps staying on top even after the 2 orders I placed since then.
