Ground Plane
How do I remove the ground plane and make my background black in DAZ Studio 4.8 Pro? Cheers
  • fixmypcmikefixmypcmike Posts: 19,743
    Go to Render Settings > Environment and set "Draw Ground" to Off.  Do you want a black background or a transparent one?
  • For the ground plane, there's an on/off switch at the bottom of the Render Settings tab>Environment. The background is on the Environment tab; the default of "none" is what gives you the transparent "checkerboard" when you render.
