universal tool
Hello, on some props, the universal tool is far from the object which makes handling very difficult. How can it be replaced in the center of the object to be manipulated?
  • Richard HaseltineRichard Haseltine Posts: 112,275
    edited February 2023
    Are you sure they are props (single nodes, not a figure with bones)? If not it may simply be that you have the figure node selected but the root bone (Hip or equivalent) has been moved. The Joint Editor can be used to move a joint centre for a prop, though.
  • Thanks for your response Richard. Indeed, by going down in the hierarchy of the object, I manage to place the tool correctly. Really, thank you.
