What's the best way to place and direct a wind node?
What's the best way to place and direct a wind node? I frankly don't understand why placing a wind node must be different from spot light or camera that provides the direct camera/spotlight view. Without such a functionality, it's time-consuming to place and direct the wind node. So I must ask the question.
  • If you want to use a camera to set direction of wind node, you can.
    1: Add wind node (options:- Apply Default settings)
    2: With wind node selected. Create:- Add new camera (options:- Copy Selected item:<dForce Wind Node>
    3: In scene tree, drag/drop the Wind node on to the camera you just created.
    The camera is now the parent of the wind node. You can view through that camera (move/rotate as you usually do), and the wind node will follow(as child to camera).
  • crosswindcrosswind Posts: 10,341
    edited February 2023
    Or if your current View is a camera or a spotlight, Create - New dForce Wind Node with Apply Active Viewport Transforms:( )... in Options. Then make a parenting.
    Or if there're cameras, lights and wind nodes in the scene already, select a camera or a light, CTRL+C, select a wind node, CTRL+V ...
    Post edited by crosswind on
  • Thank you @stem_athome and @crosswind,
    I will try it out.
