SSS disappears from my figure when I convert it to an Iray shader.
When I convert my GEN1 figure to IRAY shader, the SSS features disappear from my surfaces. Is there a way to add it back or to keep them from disappearing when I convert to the Iray Base. I know this is probably something easy, but I cannot figure it out. Any help would be greatly appreciated. Thanks in adviance!
  • JackFosterJackFoster Posts: 143
    Check to make sure "Thin Walled" is turned off. When it's on, the options for "Transmitted Color" along with the other SSS options are disabled.
  • gbmorphsgbmorphs Posts: 33
    Pefect! Thank you!!!!
    I knew it was something simple. Have a great Sunday!
    That brings up a good point — we have Iray Optimised shader converters for G2F/G2M, but what about the original Genesis, or other earlier generation figures? I think I'll put in a support ticket about this.
  • Oso3DOso3D Posts: 15,116
    It should be pretty easy, really.
  • DustRiderDustRider Posts: 2,911
    edited August 2015
    The free Skinray Alfa 1.2 from Most Digital Creations works quite well for setting up shaders on Genesis 1 and V4. Here are a couple of quick test I did using it with a V4/G4 character and a Genesis 1 character, I dropped the glossiness a bit, but the rest are the base/default settings. It includes shaders for V4/Genesis 1 and Genesis 2. I used the UHT Hair shaders in both renders.
    V4/G4
    Genesis 1
    1600 x 2000 - 630K
    Post edited by DustRider on
  • daveleitzdaveleitz Posts: 459
    DustRider, thanks for the link!
  • KeryaKerya Posts: 10,943
    There is none for Genesis3Female Base ...
