Poses that don't fit!
It's bad enough that the poses you get with a model do not fit well together but when you buy a pose package and it does not fit in with the models they''re designed to go with. Don't you make sure that the poses work before you make them available for sale!
    In what way are they not working?  What model are the poses for, and what morphs are you using?
  • The pre-set poses that you buy are a good base to start off with so you don't have to start from scratch.  You will always have to adjust them...
  • DarkSpartanDarkSpartan Posts: 1,096
    Also, if you're using a posekit with anything other than what it was designed for, you get that too. If you want a graphic demonstration of this, use Bethany's poses on Skyler. Poses are straight values, rather than relative positions of individual bodyparts. There's a reason some of the Keiko posekits came with V6 set.
