uv swap plugin for Carrara and Poser?
MistaraMistara Posts: 38,675
is anyone making a  uv swap plugin for Carrara and Poser?
or like a RTE encoder that would work inside of Poser, Carrara, DS?
laugh
    Slosh has a pack of free presets over here, with both duf and poser files. http://www.sharecg.com/v/73633/gallery/21/daz-studio/uvsettergen2-revised-10-2014?interstitial_displayed=Yes
    You still need to own the UV products though.
    so, if someone wanted to sell MilDragon textures with custom uvs, would be nice to be able to apply new uvs with the pz2 or cbr file.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,520
    Sadly even in DAZ studio where you can load new UV mapping as an obj and save it. As a support asset you cannot as far as I know redistribute those new UV's as is.
    Some have made ones that match figures like Dawn from Hivewire for Genesis etc but cannot share them in any way for example.
    using a program like UV mapper one can save a generic file for that program based on the new obj adding an rte encoder encryption requiring the original object to unencrypt it but not the dsf file found in data for the UV.
    done the uvmapperclassic uvs import/export thing between v4 and m4. was fairly painless.
    actually, uvs swap alone isn't enough for mildrag, need to change face groups too.
    You can, but there's one caveat. Poser doesn't have native UV switching. You'd need to create the new UV preset and files in DS and create Poser Companion Files.
