Feature request: select random faces/points/vertices of a surface
pixelquackpixelquack Posts: 447
edited January 2023 in Product Suggestions
[Feature request: select random faces/points/vertices of a surface] Like Blender's "Select Random" feature. Would help a lot creating modifying objects to have a varying random look, think water surfaces: select random, MeshGrabber, new look.
Edited for Please put your question in the post body and the title - Daz 3D Forums
  • I've read this 5 times and have no idea what you want.
  • felisfelis Posts: 6,642
    If you are talking about Richards correction, then he want that the content can be read fully without reference to the headline.
    That said, your options for using select random, is as far as I see it limited to mesh grabber as that is the only tool that can move mesh, so I would say you are much better off, doing it in a modelling program and then create a morph.
  • Doable but tedious. "Limited to Meshgrabber" = "limited to one of the most useful plugins in DS".
    Then maybe the PA of Mesh Grabber will make that feature as a new add-on.
  • I'll contact him indeed.
