HARDWARE: render times
Does anyone out there have any knowledge on whether running the new 4090 in a PCI-E v3 slot/MB versus a newer MB with PCIE-4 has any bearing on actual RENDER times (or any of the PCI-E v4 cards in a lesser version PCI-E bus slot)? The PCI-E v4 slot is 4x faster throughput, but I'm wondering if that really doesn't have any bearing on render times since the rendering is on-board the GPU and should be affected by bus transfer speed to the CPU.
Anyone?
  • DartanbeckDartanbeck Posts: 22,159
    Interesting if someone actually had the means to test the two. Cool question with the possibility of a cool answer. One would think that feeding those cuda core more rapidly would result in faster render times. I nkow going from a 6GB GTX to a 6GB RTX was a night and day difference on both render times and dForce simulations.
    Hope you get the answer
  • Initially this question was submitted as a sub-comment in another thread, where knowledgeable folks seem to agree that the pci-e bus should be inconsequential in rendering times. Whoohooo. Now if only it will fit in my atx-mini case.
