Problems with Keyframes
Hi all,
I'm having some issues when attempting to set Keys.
Here's the scenario:
I start a new scene, and only import a single figure, no clothing. At frame0 I set a Key with the little Key+ icon, wait for it to save and move on.
Next, let's say I move to fram30 and set an initial pose; again, I set a Key here at frame30 and wait for it to finish.
I then move to frame60 and set a new pose; Key frame, wait, etc.
Now, at this point, a majority of the time, if I move the slider back to frame0 the figure is still at Zero. I move to frame30 and it has a pose, but it's the same pose as the one that was at frame60.
This tends to happen at odd times and it makes it very difficult and frustrating to work around it.
Am I just not using the Key correctly? As far as I understood, creating a Keyframe will essentially save everything that has changed from the previous Keyframe... so why does it not always work?
Occasionally things work out, but a majority of the time it just won't stick.
Do certain poses not save with a Keyframe? Does it have anything to do with the figure being in/out of a Group?
One particular scenario, just recently, I was trying to set different poses on the timeline with the 3DU Pose Architect for G8F, which uses sliders to frame the figure into a pose; a pose @30, a different pose @60, and a third pose @90. By the time I set the Key @90, the entire time line was that same pose.. so frame30, 60, and even 0 was all the same as the last frame created @90.
Is it just that the sliders don't get saved with the Key?
I just don't understand why it does this. Any advice is appreciated.
