VisualMenus by Bitwelder
I just had to move my Content Library. With this I apparently lost all my Visual menus. As I am relying heavily on them for my workflow I am in a bit of trouble now.
They can not have been deleted but DAZ and VM itself seems to have lost all links to them. Does anyone have any idea hows to restore these links? It would save me many hours of work.
  • barbultbarbult Posts: 26,408
    edited January 2023
    Did you ever export your menus for safe keeping, as described in the user manual? If so, perhaps you can just reimport them from the Visual Menus Dashboard.
    (I tried to attach screenshot, but upload is broken again.)
    Post edited by barbult on
  • LauritaLaurita Posts: 272
    Never thought of that. :-/
    Just a wild thought.
    Why don't you change back the content folder and see if Visual Menus there again?  You need exact path syntax.  If that works then export VMs. Depending on how you changed things you might get lucky.
    Did check how Visual Menus stores its entries versus the exported backup.  Way too different.  So that way is not an option sadly.
    Use Visual Menus heavily for workflow too, so can sympthize alot.
    Export my menus after most changes. Backup everything really. Could be gone in 5 seconds with bad luck.
    Did notice a long while ago when using an exported VM save version that flipping between Beta and Regular DazStudios changed the unique GUIDS, so it wasn't without some extra work.
