Love some pants but the mashes not well on my model
Hey :)
I really really liked this pants but when I put them on my model it makes some little bug in the top as you see.
I try shaping but this pants dont have top change also Mesh Smooth but didnt work well on it , someone have more idea?
thanks! :)
711 x 457 - 478K
  • IceCrMnIceCrMn Posts: 2,334
    A product called "Fit Control" has morphs that can fix that.
    https://www.daz3d.com/fit-control-for-genesis-8-female-s
    There is also one called "Mesh Grabber" that can fix it.
    https://www.daz3d.com/mesh-grabber-win
    This one you set the smoothing on the clothes then use mesh grabber tool to click on the squares in the mesh and pull it different directions to to fix it.
    Mesh grabber doesn't really need the smoother, you can use it on any mesh to change it's shape.
    Ok then If I will buy this one Fit Control for Genesis 8 Female(s) | Daz 3D I just need to click on the pants with the mouse with left lick and I will find it in the shaping? I will buy it if it will help me :)
    edited December 2022
    Click the character.
    Then put the pants on her.
    While the character still selected you click the script "Fit Control - 01 add morphs to items" and a menu pops up with check boxes for all the clothes she wearing.
    Put a mark in each box for each item of clothes you want the morphs for and click "Accept"
    The fit control scripts are found in Genesis 8 Female>Clothing>Fit control
    Post edited by IceCrMn on
    Once you've done this you select the pants and on the Parameters pane click "actor" on the left side and a a bunch of new morphs should be there.
    There are 2 kinds of morphs for fixing the back and top of the pants listed under "rear" and "back"
    On the top right side of the Parameters pane you can type rear or back and it will show you the morphs for that part.
    I love this set of morphs,I consider it a must have.
  • foxyfoxfurriesfoxyfoxfurries Posts: 394
    I did it click accept and it's still the same , Where can I found Genesis 8 Female>Clothing>Fit control?
    556 x 344 - 104K
    531 x 273 - 278K
    165 x 408 - 12K
    Post edited by foxyfoxfurries on
    Select the pants in teh "Scene" pane.
    Switch over to the "Parameters" pane.
    Click "actor" on the left side of the tab.
    On the right side of the tab you should see a huge number of new morphs.
    On the top part Right side of the "Parameters" pane there is a search box.
    type in
    back
    To see the morphs for the back side
    You can also type in
    Rear
    To see more for the back side
    type in
    back
    Rear
     Now it working! Thank you! I can only put the pants or better select everything in my model or only what I need , And hope I make it right lol xD
    606 x 473 - 549K
    323 x 417 - 34K
    Yes, that's it you got it :)
    Well done.
    You can use it on anything,but the PA says not to use it on things like hair.
    I use it on every clothing I have becasue most don't come with any morphs at all.
    When you save your scene the morphs will save with it, so will be there when you reopen the same scene.
    Well done.
    So that's a good news then!!! Thanks for help me! :)
    You're welcome.
