Error installing assets
I am getting an install error when installing some items such as Yule cottage and Ron's Environment weather fx, etc. It is acting like it doesn' tknow where to install these, i am not sure how to get these installed so that I may use them.
Moved to technical Help as it appears to be an Install Manager issue rather than a Daz Studio issue.
Please attach your image, pasting it into the body of the post doesn't work (although i was able to see it in the Edit window while moving the thread).
Yule Cottage appears to be content for Carrara, so the installer needs to know where to put Carrara files (assumign you have the application. Ron's Weather FX isn't coming up on a store search but it is probably Photoshop brushes, so the isntaller needs to know where Photoshop is isntalled (or you need to make up a location if you want to use the brushes in another application).
