LogTemp: Warning: DazToUnreal: ERROR: Unable to parse DTU
macos 12
I builded UE5.2 and Daztounreal2022 with xcode.
it dipalyed some some warnings but builded successed.
When I send an animation to UE, Log shows LogTemp: Warning: DazToUnreal: ERROR: Unable to parse DTU
At this stage, do I have any good way to fix it?
This doesn't seem to be a big problem, but I'm not good at c++
Thank you
  • bitpartbitpart Posts: 30
    edited November 2022
    DTU FIle content:
    "DTU Version" : 4,
    "Asset Name" : "Genesis8Male",
    "Import Name" : "Genesis8Male",
    "Asset Type" : "Animation",
    "Use Experimental Animation Transfer" : false,
    "Asset Id" : "Genesis8Male",
    "Content Type" : "Actor/Character",
    "FBX File" : "/Users/liuyu/Documents/DazToUnreal/Genesis8Male/Genesis8Male.fbx",
    "Base FBX File" : "/Users/liuyu/Documents/DazToUnreal/Genesis8Male/Genesis8Male_base.fbx",
    "HD FBX File" : "/Users/liuyu/Documents/DazToUnreal/Genesis8Male/Genesis8Male_HD.fbx",
    "Import Folder" : "/Users/liuyu/Documents/DazToUnreal/Genesis8Male/",
    "Product Name" : "",
    "Product Component Name" : "",
    "Materials" : [
    "Version" : 4,
    "Asset Label" : "Genesis 8 Male",
    "Material Name" : "Face",
    "Material Type" : "Iray Uber",
    "Value" : "Actor/Character",
    "Properties" : [
    "Name" : "Asset Type",
    "Label" : "Asset Type",
    "Data Type" : "String",
    "Texture" : ""
    "Name" : "UV Set",
    "Label" : "UV Set",
    "Value" : 0,
    "Data Type" : "Double",
    "Texture" : ""
    "Name" : "Smooth On",
    "Label" : "Smooth",
    "Value" : 1,
    "Texture" : ""
    "Name" : "Smooth Angle",
    "Label" : "Angle",
    "Value" : 89.9,
    "Texture" : ""
    "Name" : "Line Preview Color",
    "Label" : "Line Preview Color",
    "Value" : "#000000",
    "Data Type" : "Color",
    "Texture" : ""
    "Name" : "Line Start Width",
    "Label" : "Line Start Width (mm)",
    "Value" : 0.1,
    "Texture" : ""
    "Name" : "Line End Width",
    "Label" : "Line End Width (mm)",
    "Value" : 0.1,
    "Texture" : ""
    Post edited by bitpart on
  • It's too long. I can only copy part of it
  • Attach the log rather than trying to paste it into the body.
    Is this ok?
    1920 x 1080 - 576K
  • It works after i changed "Intermiediate Folder", It may be caused by Chinese characters.Thank you!
    513 x 669 - 184K
