Physics Simulator
Can anyone tell me if Fisio: Physics Simulator also works with Genesis characters?
  • Probably not in the way you want since soft body physics is not included. However, an add-on is planned:
    https://www.daz3d.com/forums/discussion/comment/7860016/#Comment_7860016
  • I suspect you want a rag-doll simulation, which is probably different again.
  • AlbertoAlberto Posts: 1,474
    As Charlie said, there will be a soft-body add-on. But, in the meantime:
    1. You can define any figure (including Genesis figures) as Fixed. Then you can animate it, and all the other bodies will react to the figure and its movements (but not vice versa).
    2. You can define any figure as not Fixed, then the plugin will treat it as a Rigid-body. However, you can animate this figure as usual (morphs and posing) and the plugin will adapt to the changes.
