Transfer Utility Problems
Hello! I've been dabling at creating a few things using marvelous designer and then transfering them back into DAZ. My most recent one was a short that appears to load into DAZ on M6 with problems (everything fits as it should). However, once I run the transfer utility, the item jumps up and everything is no off. I've tried every which way I could possibly come up with to fix this, but I just have run out of ideas on this one. Please help!! :)
Thanks,
Jason
    You model to the zeroed base figure.  Which would be G2M...
    Or you need to 'Reverse Source Shape from Target'.
    What's happening are any scaling or translations are being doubled.
  • fixmypcmikefixmypcmike Posts: 19,743
    Yes, you need to make sure scaling has been removed, as that isn't part of the reverse deformation adjustment.
