Problem with rendering
Hi,since yesterday evening I have a problem with daz,after about 2 seconds after clicking the render button the application pauses rendering with a blank window.From the logs it looks like not enough vram but earlier I rendered images on this scene and nothing like this happened One g
2022-11-17 13:56:39.214 [INFO] :: Rendering image
2022-11-17 13:56:41.332 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating geometry.
2022-11-17 13:56:41.332 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating motion transforms.
2022-11-17 13:56:41.333 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Importing scene graph.
2022-11-17 13:56:41.536 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Auto instancing compression ratio 1.00 (Full instancing compression ratio 1.00)
2022-11-17 13:56:41.536 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Importing geometry for motion time 0
2022-11-17 13:56:41.730 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Geometry import (1 triangle object with 3 M triangles, 0 fiber objects with 0 fibers (0 segments), 1 triangle instance yielding 3 M triangles, 0 fiber instances yielding 0 segments) took 0.194 s
2022-11-17 13:56:41.731 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating section objects.
2022-11-17 13:56:41.731 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating materials.
2022-11-17 13:56:41.838 Iray [INFO] - MATCNV:RENDER :: 1.0 MATCNV rend info : found 232 textures, 0 lambdas (0 unique)
2022-11-17 13:56:41.848 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Emitter geometry import (13 light sources with 15122 triangles, 1 instance) took 0.001 s
2022-11-17 13:56:41.848 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating volumes.
2022-11-17 13:56:41.849 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating environment.
2022-11-17 13:56:41.849 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating lens.
2022-11-17 13:56:41.849 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating lights.
2022-11-17 13:56:41.849 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating object flags.
2022-11-17 13:56:41.850 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating backplate.
2022-11-17 13:56:41.853 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating caustic portals.
2022-11-17 13:56:41.854 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating decals.
2022-11-17 13:56:41.861 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Using iray core convergence estimate.
2022-11-17 13:56:41.861 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Allocating 1-layer frame buffer
2022-11-17 13:56:41.869 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Using batch scheduling, caustic sampler disabled
2022-11-17 13:56:41.869 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Initializing local rendering.
2022-11-17 13:56:41.872 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Initializing OptiX Prime for CUDA device 0
2022-11-17 13:56:41.877 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering with 1 device(s):
2022-11-17 13:56:41.877 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : CUDA device 0 (NVIDIA GeForce GTX 1080)
2022-11-17 13:56:41.877 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering...
2022-11-17 13:56:41.877 Iray [INFO] - IRAY:RENDER :: 1.9 IRAY rend progr: CUDA device 0 (NVIDIA GeForce GTX 1080): Processing scene...
2022-11-17 13:56:42.332 Iray [INFO] - IRAY:RENDER :: 1.3 IRAY rend info : Importing lights for motion time 0
2022-11-17 13:56:42.332 Iray [INFO] - IRAY:RENDER :: 1.3 IRAY rend info : Initializing light hierarchy.
2022-11-17 13:56:42.519 Iray [INFO] - IRAY:RENDER :: 1.3 IRAY rend info : Light hierarchy initialization took 0.187 s
2022-11-17 13:56:42.550 Iray [INFO] - IRAY:RENDER :: 1.9 IRAY rend info : CUDA device 0 (NVIDIA GeForce GTX 1080): Scene processed in 0.673s
2022-11-17 13:56:42.550 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER :: 1.9 IRAY rend error: CUDA device 0 (NVIDIA GeForce GTX 1080): Not enough memory for kernel launches (222.797 MiB (354.047 MiB) required, 0.000 B available). Cannot allocate framebuffer.
2022-11-17 13:56:42.550 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER :: 1.9 IRAY rend error: CUDA device 0 (NVIDIA GeForce GTX 1080): Failed to setup device frame buffer
2022-11-17 13:56:42.550 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER :: 1.9 IRAY rend error: CUDA device 0 (NVIDIA GeForce GTX 1080): Device failed while rendering
2022-11-17 13:56:42.550 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [WARNING] - IRAY:RENDER :: 1.9 IRAY rend warn : CUDA device 0 (NVIDIA GeForce GTX 1080) ran out of memory and is temporarily unavailable for rendering.
2022-11-17 13:56:42.555 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [WARNING] - IRAY:RENDER :: 1.9 IRAY rend warn : All available GPUs failed.
2022-11-17 13:56:42.555 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER :: 1.9 IRAY rend error: Fallback to CPU not allowed.
2022-11-17 13:56:42.555 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER :: 1.9 IRAY rend error: All workers failed: aborting render
2022-11-17 13:56:42.555 [ERROR] Iray :: Internal rendering error.
2022-11-17 13:56:42.717 [INFO] :: Saved image: C:\Users\\AppData\Roaming\DAZ 3D\Studio4\temp\render\r.png
2022-11-17 13:56:42.724 [INFO] :: Finished Rendering
2022-11-17 13:56:42.776 [INFO] :: Total Rendering Time: 3.65 seconds
2022-11-17 13:56:46.144 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Device statistics:
2022-11-17 13:56:46.144 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : CUDA device 0 (NVIDIA GeForce GTX 1080): 0 iterations, 0.679s init, 0.005s render
one character and a small room The card is gtx1080 and the scene takes only 300mbvram
What happens if you try to render with 3Delight, does that work or also generate some errors? You may want to start by trying to rule out possible issues. If 3Delight works as intended, then what happens if you switch your viewport to Filament and then also Iray?
3Dlight works normally, if I switch to iray view, it looks stuck, image doesn't "clear"
Your log is saying that you have run out of VRam and that CPU is not enabled. If you think the scene should not be using that much might save and restart the computer to see if that frees it up.
Also if you are trying to render with iray preview on that takes up vram also.
On a windows system I like to use "Task Manager" to monitor my GPU usage. Right click on lower task bar, select Task Manager. Select the "Performance" tab in Task Manager. On the left there shoud be a GPU listed ... pick your GPU and it will tell you lots about the resource usage for the GPU.
