Adjusting Length
Is there a product available that would enable me to shorten the length of a shirt or a dress please?
  • felisfelis Posts: 6,497
    edited November 2022
    Not directly.
    There is mesh grabber which can move mesh.
    Or dFormer, whivh might be better for shortening something.
    But a better way to do it, in my view, is to take it into a modeller and make a morph.
    Post edited by felis on
  • glennblackphotosglennblackphotos Posts: 160
    felis said:
    Not directly.
    Thanks can you recommends any tutorials on how to do that please?
    I know there is a tutorial by Sickleyeild, but I couldn't find it.
    If you search, then there are a number of tutials, that should give the feel for it, but I didn't see any I knew and would recommned. But I suggest you look at some to get a feel for it.
    Steps to create a morph
    1) Export the clothing out of Daz Studio in default shape and base resolution as an Obj
    2) Import you clothing into a modeller and do the change
    3) Export the clothing back as an Obj
    4) In Daz Studio select your clothing in the scene tab and enable morph loader pro
    5) In morph loader pro select the modified Obj file and create morph
    With some luck it should then create your morph
    For the actual change of making something shorter in the modeller, I would select the lower row of faces and enable proportional editing (that is a blender term, but the only modeller I know), adjust size of effected area and move upwards.
    A potentially easier method, as creating a morph might be overwelming, is to make the lower area of the clothing invisible using a mask in cut-out oppacite. A black mask will make it invisible.
    Do you have a link to the items you want to modify?
  • surv0101surv0101 Posts: 84
    glennblackphotos said:
    felis said:
    Not directly.
    Here Jay is using Hexagon to do exactly that...shorten a dress length and sleeve length.
    Creating DAZ Clothing Fit Morphs with Hexagon - YouTube
    Post edited by surv0101 on
  • NeesdNeesd Posts: 2
    edited May 2024
    There is a way. Use surface selection. Make a new surface for the clothes that you want to hide, create a new surface with it, and in the surfaces tab, set the opacity of the surface to zero.
    Post edited by Neesd on
