Render Library Location?
DarkElf
I am using the latest ( non-beta) release of DS: 4.21.0.5
I have set my render library location to where I always do:
Yet, after rendering and saving an image, it cannot be found in my render library.
Anyone have any thoughts on this?
469 x 462 - 27K
Post edited by DarkElf on
Are there certain characters that cannot be used in the file name when saving an image?
Would certain characters cause an image to not be seen in the render library?
Okay. So, I did a search for my missing render and found it on my C drive rather than the D drive that you can see I set it too.
What am I doing wrong?
Did you use the save button in the render pane or File>Save Last Render.? If it was the pane, was it set to save to the Render Library or to a folder (there is a button to the left of the library/folder name)?
I entered the name and clicked the save button. Not sure about the left side button of which you speak. I'll have to do another quick render to see what happens when I go to save.
Thanks Richard.
Richard, I did a test render and went to save it and saw what you are talking about. It was indeed set to the C drive. So, I messed around with things there and found out how to tell DS to save to the render library on my D drive.
Thank you for your help with this.
You are the nest!
