dForce Modifier
MelissaGTMelissaGT Posts: 2,611
edited October 2022 in The Commons
Ok, so I've updated to DS 4.21...and did the location of adding a dForce modifier change? It was always under Geometry...in the same menu as adding a push modifier or smoothing modifer. But...it's not there anymore. Was it moved?
*edit* I found it in the main Edit menu...I used to get to it directly from the scene panel. Doesn't look like I can get to it that way anymore...oh well.
Post edited by MelissaGT on
  • MadaMada Posts: 2,080
    edited October 2022
    Did you run update and merge menus? My first go to when things shift around - 90% of the time it will fix things :)
    434 x 320 - 32K
    Post edited by Mada on
  • SevrinSevrin Posts: 6,314
    dForce options are also available from the hamburger icon on the Sim Settings tab
