Tesla3dCorp Dance studio bug - Timeline
toddjwendttoddjwendt Posts: 6
edited October 2022 in Product Suggestions
Hey folks,
Lettting you know that I've discovered a pretty significant bug with the Dance Studio.  When I use the timeline and attempt to set up a sequence, clicking any time beyond zero causes the whole set to move.  I will show a before and after image below.  So, I went into the time line (set at zero) and keyframes are marked there for every peice in the set.  If I remove them, the set then deconstructs and moves to the center of the world, every time.  Frankly, unless I'm taking a still shot that doesn't require Dforce simulations, it makes the studio completely useless.
Any ideas on how to fix this?
Thanks,
Todd
2550 x 1399 - 476K
2560 x 1440 - 519K
2560 x 1440 - 2M
2560 x 1440 - 2M
Post edited by toddjwendt on
  • NorthOf45NorthOf45 Posts: 5,926
    It is probably the same problem as seen in their Hospital Corridor. See this thread for the likely solution: Problem with Tesla3D Hospital Corridor
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,819
    edited October 2022
    their products are renowned for this, I will only buy them when exceptionality cheap because of this.
    expand the timeline and select and delete the extra keyframes then resave as a scene subset under a new name ie fixed
  • It's a shame to dare to sell a product that the buyer has to fix before they can use it. Kudos to quality control too!
  • oops Stoney did a Tesla3Dcorp  errorblush
    anyway video, easy fix
  • Several items of the studio clump together the moment you move the animation tool. Nothing is working. I tried  zeroing objects and figures for these items and I deleted them and reinstalled them one at a time and it still nothing worked.
    Any help would be greatly welcomed.
    Thank you
    Anthony
  • Richard HaseltineRichard Haseltine Posts: 112,003
    Thank you
    Anthony
    Did you try selecting them in frame 0, before they move, and then Edit>Object>Clear Animation>Clear Selected Item(s)?
  • FSMCDesignsFSMCDesigns Posts: 12,858
    Thank you
    Anthony
    That doesn't work Richard. Just tried it on several TeslaCorp items that suffer from this
    Thank you
    Anthony
    You did have all the affected nodes selected, not just the roots of the hierarchies?
     Yes. The problem is when you clear it, it all moves to the center like it does when you advance the animation timeline
