• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Texture traces when I change material in Blender
mertozel0mertozel0 Posts: 3
October 2022 edited October 2022 in Blender Discussion
When I send my figure to Blender (Bridge or Diffeomorphic, same problem occurs) there is always a mark which most noticable in the shoulder parts. Of course it occurs when I change material, especially to glass. I mostly delete all materials and create another one but I tried to change one of the existing ones, tried couple of methots, checked the mesh etc. but couldn't figure it out what happens there. I want to get rid of it. Thank you.
856 x 1502 - 2M
1388 x 1060 - 2M
Post edited by mertozel0 on October 2022
  • PadonePadone Posts: 4,377
    October 2022
    Please post pictures and the exact steps to reproduce the issue.
  • mertozel0mertozel0 Posts: 3
    October 2022
    I'm sorry I forgot to add them, added now.
    If you're using a volume shader there's a bug in blender 3.3.
    https://bitbucket.org/Diffeomorphic/import_daz/issues/1168/
    As for the marble texture in your second picture, if you use the same texture for all the body parts then it is just normal that you get texture seams. You have to use different textures and paint them seamless. This is so in any 3d app.
    Post edited by Padone on October 2022
    Thanks but actually this was happening in 3.2 too and I tried 3.4 and it's still the same. It looks as it supposed to be with Daz's textures but this occurs when I put simple BSDF with transmission. It appears more as I increase transmission, so no volume shader.
    Edit: Also choosing full global illumination didn't solve the problem. I've tried couple of things with lights and render setting but no solution. I think it's about mesh itself for some kind.
    I don't know what you're doing with your materials, but here is an example that you can study it works fine. Import it with single principled to get the principled version in blender. It's a "glossy" G8F.
    duf
    duf
    glossy.duf
    103K
    640 x 360 - 21K
    October 2022
    I've tried your file but I got the same result. What do you mean by  "Import it with single principled"?
    The thing is I delete all materials and create new simple one but those texture marks still appears even though they are deleted. I'm definitely missing something, I'm trying to explain it with screenshots.
    1816 x 1966 - 3M
    1898 x 1838 - 3M
    1974 x 1966 - 4M
    October 2022
    Sorry I can't reproduce the issue, here everything works fine without seams. Are your render settings good enough ? Try with full global illumination. Or try rendering with the cpu to see if it's the card drivers that go nuts.
    1. import the figure
    2. delete all materials
    3. create a new material and set transmission = 1
    809 x 254 - 80K
    October 2022
    I think you didn't set roughness to 0, mine looks same as your screenshot when I use 0.5 roughness. You should see the problem when you set it to 0, I'm really wondering your result. Thanks again for your help.
    Yes I can reproduce the issue now. But it's not a issue. That is, it's just how refraction works related to the environment map, depending on the camera angle and geometry shape you may get "seams" on the reflection. It happens the same in iray, or in cycles with another mesh as suzanne. Below it's a iray rendering with zero roughness, test scene included glossy-seam.duf.
    note. Please note that this is not related to the uv map/textures, you can delete the uv map in blender and you get the same "seams".
    640 x 360 - 73K
    duf
    duf
    glossy-seam.duf
    102K
    455 x 263 - 33K
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
