Looking for a bathroom scale
chris-2599934
I'm looking for something for my characters to weigh themselves on.
I have this: https://www.daz3d.com/floor-scales but it's a bit too old-fashioned. I want the sort where you stand on a panel and there's a readout (digital or analog) of what your weight is.
I've been through my collection of bathrooms and doctors' offices, but none of them contain a set of scales. Can anyone point one out to me?
https://www.daz3d.com/before-poses-for-v5
https://www.daz3d.com/before-poses-for-genesis-v5-and-m5-bundle contains a dark version.
Found this one: https://www.renderosity.com/rr/mod/bcs/dks-bathscale/126571/
And two freebies:
https://www.renderosity.com/freestuff/items/42193/bathroom-scales-prop-site-link
https://www.renderosity.com/freestuff/items/87108/bathroom-scale-pese-personne
There is an adequate one here: https://www.renderosity.com/freestuff/items/57494/scale, but it's no good if you can't read Rhino files. I have opened it with SolidWorks, but the model that gets into SolidWorks isn't ideal for conversion to obj and then DS (lots of sharp triangles that will shade oddly in DS) and it'd almost be easier to make one from scratch than make that one work.
There is an old Poser one here by Adam Thwaites: https://www.most-digital-creations.com/free_poser_poses_textures_morphs_props_13.htm (second from bottom). It would need updating the shaders.
Failing that... the question has to be 'Is that good enough and if not, how urgent & how accurate do you need it?". If it's very urgent & not accurate, you could texture map a cuboid primitive in DS and use the 'Round corners' feature on the iRay Uber shader to smooth the edges.
Failing that.. If you can wait to the weekend I could model & rig one up for you. I'd like to say tonight, but realistically it's not practical until the weekend. Which units do you prefer to use on your scales? Stones + pounds/ kilogrammes/ pounds only/ troy ounces/ something else? And what range, 0-20 stone/ 0-127kg/ 0-280lb/ 0-4083 troy ounce (all those are virtually the same)?
So, a few options..
Regards,
Richard
Thanks guys, I downloaded the Adam Thwaites one, which scrubs up quite nicely into iray.
