Edit -> Element Data
In the past, I was able to find Edit -> Element Data in the Scene Panel Hamburger Menu, but in the 4.20.1.78 Beta, I no longer see the option there. How do I access this menu item now?
Thanks in advance if anyone can clue me in!
- Greg
  • hansolocambohansolocambo Posts: 649
    edited September 2022
    Post edited by hansolocambo on
  • barbultbarbult Posts: 27,660
    On the main menu there is Edit>Scene>Scene Data... is that the same thing?
  • After some further investigation, it seems as though Edit -> Element Data may have been split into Edit -> Scene Data and Edit -> Node Data. I had originally thought that they may not serve the same function because the dialog no longer says "Edit Post Load Data Items", but instead says "Data Items : Scene" or "Data Items : <selected node name>".
    In any event, I was able to get the desired effect using Scene Data - cheers!
    - Greg
  • See http://docs.daz3d.com/doku.php/public/software/dazstudio/4/change_log#4_20_1_73
    "Element Data" was re-labled to "Node Data" (to reflect actual context), "Scene Data" is new, "Surface Data" is new, as is a new API only "Element Data" (proper) for other non-discrete element types. Each serves a different, albeit related, purpose.
