• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Better Blender to UE5 bridge for Daz content
catmastercatmaster Posts: 226
September 2022 edited September 2022 in Blender Discussion
Direct plugins are always better than FBX exporters, Diffeomorphic is the best Daz to Blender pipeline because it translates from Daz native to Blender native. There needs to be such direct bridge between Blender and UE5.
Official Blender SendToUnreal plugin from Epic requires lots of manual work inside UE5, because it does not rebuild PBR materials, and does not keep unbaked animation keyframes, lighting settings, camera movement etc.
There are alternative pipelines than FBX methods, the USD (Universal Scene Description) file format or using Datasmith Blender addon:
Currently the reliable method from Blender to UE5 is to rebuild the materials and other settings in UE5.
Post edited by catmaster on September 2022
  • catmastercatmaster Posts: 226
    Checked DazToUnreal update there are exciting new features: "New geograft material support, preliminary support for geograft morphs".
    https://github.com/daz3d/DazToUnreal/releases
    Diffeomorphic recently added features to import Blender animations to Daz.
    Would try the new workflow Blender -> Daz -> UE5 and test if the geografts work as expected.
    Tested DazToUnreal v2022.2.18 there were some problems:
    Outfits such as necklace were not correctly attached to body after imported.
    After imported to UE5 the breasts were clipping through bras with custom morphs from Breastacular.
    Geograft materials from Breastacular were not imported.
    Custom geograft morphs from "LK Morphs And Shapes For G8F Genitalia" were not imported.
    Custom body morphs from "Xtreme Penetration Morphs" were imported and worked as expected, however these are not geograft morphs, they are located on the Genesis 8 Female parameters.
    MeiLin8 and Facegen morphed character based on MeiLin8 were used for testing.
    There are some nice improvements with this update, most notably the eyes and hair materials are correctly rebuilt.
    To fix the geograft morphs there is workaround as suggested on Unreal forum, copy the geograft morphs to the body model:
    Exporting Geoshells from Daz3d to Unreal Engine 5:
    The DazToUnreal bridge works as most effortless pipeline from Daz to UE5.
    Using Blender with Diffeomorphic importer gives full control of Daz assets.
    3840 x 2160 - 2M
    Found that the material slots in UE5 can be copied from one mesh to another, so that rebuilding materials is not difficult.
    Method 1: Fix the geograft morphs and textures in Daz and Photoshop -> Export to UE5 with DazToUnreal
    Method 2: Export to Blender with Diffeomorphic -> Import morphs and merge geografts -> Use the Blender plugin SKkeeper - The Shapekey Keeper to bake HD meshes with morphs -> Export to UE5 with Blender FBX export -> Copy materials from DazToUnreal imported character to the character imported from Blender
    Attached the results in UE5 from the same character, but using different methods to export to UE5.
    Update: DazToUnreal has a serious bug that it duplicates the geograft in UE5 after export, also it can't correctly export animations to UE5, the face is distorted during animation.
    Method 2 is the correct way to export characters to UE5 with geograft morphs and animations. Diffeomorphic is essential to export geografts and animations from Daz to UE5, DazToUnreal is optional it's used for copying the materials but you can rebuild better materials in UE5.
  • PadonePadone Posts: 4,313
    September 2022
    As for materials one way is to use the "single principled" method in diffeomorphic, so to use a single principled node that will export better to fbx. Of course some materials will need to be fixed since a single principled node is limited in what it can do.
  • marek_bmarek_b Posts: 26
    February 2023
    From my personal experience I can say that the best workflow and cinematic quality is to export from Daz to Blender Genesis 8 character in FBX format and then add "mdd" animation done in DAZ.
    Then export alembic to unreal. Here you have to create all materials including those for the eyes, there is no need to replace them. In my opinion, alembic format is essential for extreme poses. Of course I tried exporting FBX animations from Blender
    with use of diffeomorphic but the results are not so good.
    I am attaching some pictures of my work.
    Sincerely
    3062 x 1956 - 2M
    3062 x 2259 - 2M
    3062 x 1920 - 1M
  • butaixianranbutaixianran Posts: 161
    February 2023 edited February 2023
    You guys don't know about gltf 2.0 format, don't you? Just search it. It is kind of a fbx for PBR generation.
    Post edited by butaixianran on February 2023
    June 2023 edited June 2023
    Sincerely
    Alembic format takes too much disk space, and currently not practical for controlling animations in UE5, for example any big game would need several thousands of animations not including retargeted variations for compatible characters. The FBX pipeline is deeply integrated into the engine and the animation processing, it would likely not change for decades and the ML deformer is used for pose correction added to the FBX results but not going to replace that.
    Post edited by catmaster on June 2023
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
