Dark Objects
So I hope I'm in the right spot. I've found a number of ways to make a specific object into a light source, like a sword that's supposed to glow like a light bulb. For one of my renders, though, I'm wanting to do the opposite; I need an object that absorbs light like a black hole, so that everything around it looks darker. If there a way to do this? I primarily use 3Delight, but I can use Iray if that's the only way to accomplish this.
  • nemesis10nemesis10 Posts: 3,999
    If you don't mind iRay, https://www.daz3d.com/dark-matter-shaders has the coolest black shader!
    edited September 2022
    Try a spotlight with negative light intensity!  You need to turn limits off in parameters settings. [3DL]
    Post edited by Sven Dullah on
  • In iRay a negative emissivity works. Make the colour white and it darkens everything. Make at a colour and you darken and tint. Regards, Richard
    It works in 3Delight too, will post some renders...
    ...ok, an emissive lightplane as ceiling light, UE2 in bounce/GI mode, a sphere with a dz default surface:
    ,,,with the sphere made emissive (physical falloff on):
    ...with negative diffuse- ambient- and lightstrength:
    ...and, as suggested by @richardandtracy, white emissive color and pure black diffuse- ambient color, negative lightstrength:
    In 3Delight one could play with light falloff, shadow color and whatnot, to get a result that has absolutely nothing to do with PBR:)) The last render, if using no falloff, would be pitch black.
    800 x 450 - 457K
    800 x 450 - 476K
    800 x 450 - 507K
    800 x 450 - 383K
    And, of course, forgot to mention negative occlusionwink
    800 x 450 - 385K
  • Really cool stuff.  I always enjoy your posts but many times fail to comment and tell you!  Thank you.
