• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Transferring Vertex Groups (Hair Particle System workflow)
lilweeplilweep Posts: 2,760
September 2022 edited September 2022 in Blender Discussion
Goal
I made a particle system hair on one Diffeomorphic-imported figure and I want to use it on another Diffeomorphic-imported figure.
Problem
I have not had much success transferring the particle system hair across to different figures.
The actual Particle System itself (i.e., the style curve particles) can be transferred over easily enough by copying modifiers, but the corresponding Vertex Groups that define the hair density do not transfer properly from one mesh to another.   So only the particle strands show but none of the children strands show.
When I attempt to transfer the Vertex Groups by transferring mesh data (either by using Ctrl+L or ortherwise by using a Transfer Mesh modifier), the results are always the same.  The Vertex Group gets distorted as per pictures below.
  • 1 = the vertex group i want to transfer
  • 2 = the result of using the transfer mesh modifier shown in 3
513 x 547 - 28K
601 x 722 - 39K
391 x 388 - 31K
Post edited by lilweep on September 2022
  • lilweeplilweep Posts: 2,760
    I assume someone else has already worked out a functioning workflow for using Particle System hair and transferring between different meshes, so might help if someone outined that for me here, since that is my endgoal anyway.
    I already attempted a workaround.  Instead of using Vertex Groups, I'm trying Textures to drive the density and clumping and this approach is only somewhat functional.
    One of the problems is that it stops the Cycles render in viewport for some reason (and no I dont have pause preview render clicked).
    In general Texture painting gives more finesse in describing the areas to grow hair but seems to be a lot laggier because I guess its culling the hair density after the fact rather than before?  I would much rather use Vertex Groups as the primary way to control the Density, and then maybe only use Texture to further refine it if needed.
    September 2022
    So y'all are really out here remaking your particle hair every time you want to use it on another character huh?
  • andya_b341b7c5f5andya_b341b7c5f5 Posts: 694
    September 2022
    Have you tried the Copy Vertex Weight to Selected option in the Vertex Group Specials menu, or enabling the built-in Copy Attributes Menu add-on and using Ctrl-C?  Both work for me, with objects that are copies of one another so vertex number and order are identical.  I doubt it will work (well) by any method otherwise.
    322 x 597 - 52K
    1919 x 1021 - 319K
  • Krys KryngleKrys Kryngle Posts: 313
    September 2022
    Make your particle hair on a separate mesh and then wrap/parent that mesh to the character.  This is pretty common practice.  Many hair styles that you import will already have the hair attached to a separate mesh, often called the 'scalp' for head hair.  You can then import the 'scalp' mesh into another project and it will bring the particle system along.
  • PadonePadone Posts: 4,041
    September 2022
    If the figures are the same generation you don't need to transfer but just to copy because the vertex number and order will be the same.
    September 2022
    hmm tried both and neither worked:
    • Copying the Vertex Weight to Selected on Vertex Groups Specials menu
    • Copying using copy attributes add-on
    Maybe the topology hasnt been preserved
    Does merging geografts maintain vertex order (assuming the two figures are same generation and geografts are the same)?
    September 2022
    @lilweep May be I don't know, but you better copy the maps before merging the geografts, or editing the geometry in any other way.
    September 2022
    Okay, I did some experiments and confirmed that merging geografts does not conserve vertex order.
    Whatever happened to the Geometry Nodes option?
    629 x 904 - 112K
    how do i do this, by the way? (the wrapping/parenting part)
    September 2022
    @lilweep The geometry node option is there as always, though I wouldn't advise to use it in production since geometry nodes are experimental yet.
    September 2022
    is it tho? (version 1.6)
    497 x 337 - 27K
    September 2022
    You're probably using an old version of the plugin, you need to get the dev version for the new features.
    229 x 235 - 16K
    September 2022
    oh
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
