HELP. Duplicate formulas found
Ok so my daz studio (4.16) is messed up
I have installed a good number of figures ( G8 & 8.1 mainly) today and I am now getting this message pop up when I  load a G8 figure (Duplicate formulas found in files)
I click ok and the figure loads fine and I can carry on no problems noted.
please only reply if you know how to fix it
thanks I hope ahead of time, hope your have a good weekend
  • Most likely that means that two of the characters you isntalled use the same name for one or more of their properties and that the links that allow one property to drive anothe are therefore apaprently referring to the same thing (e.g. you have Thingy's JaneDoe and Whosit's JaneDoe, both have a full body controller named FBMJaneDoe and a head morph named FHMJaneDoe - when the links in each say that FBMJaneDoe should set FHMJaneDoe they are using exactly the same names - and in this case probably the same values). Help>Troubleshooting>View Log File and search for duplicate should find one of the conflciting pair, you will then have to try to work out which the other one is from the name. Check to be sure you have the latest builds of the characters involved and if you do please report the issue  to Daz (for characters from the Daz store) or the creator (for other characters).
  • thanks Richard
  • After sorting out RL problems I have now submitted a request to daz.
    thanks again Richard
    You can delete one of the morphs causing the conflict until it is resolved.
    I have found the Turbo Loader product is a great way to temporarily remove morphs easily. It is also good for trouble shooting, since it lists all your installed morphs in an easy to digest way. Plus if by chance this is never resolved or you have conflicts by content made outside the Daz store, Turbo Loader is a good way to handle them without actually nuking the products from your library.
  • myotherworldmyotherworld Posts: 664
    edited September 2022
    Thank you for this info.
    I got turbo loader some time ago but never goy around to looking at it.
    After 10 mins i foung one of the duplicate formulas lacey shoe pose, untick it and bingo figure loads no problem.
    So many thanks outrider42.
    just waiting for tec support to come up with a fix, i did install DS4.2 after they said they could not help with DS4.16 and I should install the beta.
    I jumped in with both feet and installed DS4.20 it did jack to fix this
     I think (therefor am a danger)
    Post edited by myotherworld on
