• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Diffeomorphic and SSS parameters
marth_emarth_e Posts: 191
August 2022 in Blender Discussion
I exported my Daz Character to Blender using the amazing Diffeomorphic addon. I used the BSDF materials conversion method but I would like to play with the SSS parameters. Does anyone know which are the parameters to change using the BSDF shader? In which nodes? I also would like to know which are the standard values that you recommend for emulating human skin.
Thanks in advance,
Martha
  • PadonePadone Posts: 4,376
    August 2022
    If you want a realistic human skin then go for a custom blender shader. The iray skins are not realistic because iray doesn't support sss.
    https://blendermarket.com/products/dermis-shader
    As for diffeomorphic, the bsdf option is designed for a good iray conversion, but not to be easily edited by the user. If you want to edit your materials then go for the principled option.
  • marth_emarth_e Posts: 191
    August 2022
    Thanks, Padone.
    Let me explain you my case. I'm rendering using EEVEE (not cycles) and I have already tweaked the BSDF shader that Diffeomorphic converts and I'm very, very satisfied with the result. The only thing that I want to adjust is that I have too much SSS to the point that light is penetrating the fingers and part of the hands. So I would just would like to reduce a litlle the subsurface scattering and I think I will have a very realistic skin shader for EEVEE. Is this possible  to do? Maybe using the material editor within Diffeomorphic? I have been tweaking some of the values in the translucency section of Diffeomorphic's material editor with different results, specially with the radius and the scale parameters but I'm not sure if that is the right way to do it. Any ideas?
    Thanks a lot,
    Martha
  • Richard HaseltineRichard Haseltine Posts: 111,996
    August 2022
    In what sense?
    August 2022
    @Richard Because the iray sss is a full volumetric solution, it models volumes not subsurfaces. If you want a realistic subsurface effect using iray then you have to model the variuos skin layers with geometry, then give volume to each of them. In the discussion dedicated to realistic rendering there were some experiments about this, where a inner layer of geometry was used.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
