I failed in my search, how to have 2 versions Daz 4.6 & 4.8
XaatXuun
I want to see if my machine can use 4.8, I have not yet used 4.7, I’m still using 4.6
I know there is a way, of having 2 different versions of daz, I’m just having a problem finding it.
My machine specs pretty much sez no for 4.7 or 4.8, but I want to see if I could still make it work
please, is it possible someone could show me the link for having 2 versions . . instruction . . . . seems I should know how, but like my Machine . . not enough Memory
Post edited by XaatXuun on
In order to have two versions of DAZ Studio on the same machine (of the same bit depth) you would need to have, say, DS4.6 release version and DS4.8 Beta version.
You can also do it by having DS4.6 32 bit and DS4.8 64 bit installed at the same time.
If you want DS4.8 beta, you will have to use DIM (DAZ Install Manager) to get it, there is no other way.
okay thanks
I have a couple old HDD's someplace, maybe I can try that way, having one installed on it
Check your inbox
thank you for the info, specially the part of needed space, I had totally spaced thinking about that part.
What did WhiteFox send you? In my thread, everyone is saying no.
@Pippen I PM'd you. I hope the info helps.
There are several users that claim to have installed two versions at once but it is not advisable by DAZ so if something goes wrong don't complain to tech support.
See here - http://www.daz3d.com/forums/discussion/comment/872061/#Comment_872061
