Problems with put Objects in a group
Hi all,
i import a .dae file and it works fine. All the objects are at the place they must be.
Now i create a new group and put some objects in the new group and the objects moved to a wrong place.
So i had to move the objects in the group to the correct place again.
The same thing when i parent thes objects.
Is there problem with the group / parent function ? ... i think that work correct a long time ago
Thank for help :)
Post edited by methusalem210035 on
  • Richard HaseltineRichard Haseltine Posts: 111,612
    Make sure that Parent In Place is on - if you are using the change parent dialogue it's a checkbox at the bottom, if you are dragging and dropping in the Scene pane it's a checkable item in the pane's option menu (the lined/hamburger button in the top corner, or right-click the tab).
  • That was the problem :)
    Thank you very much
