• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
What's going on with Diffeomorphic's SSS Settings?
SadRobotSadRobot Posts: 116
July 2022 edited July 2022 in Blender Discussion
The default Principled method shader for Daz characters has some odd SSS settings (see screenshot). They result in very dark skin (but admittedly skin that looks like Daz/iRay skin). Changing these settings (to Subsurface at like .01, and the individual values to 1.0, 0.3, and 0.2, which is a more common Blender setup) makes the skin significantly lighter--but I really don't understand why. Can anyone explain why this works this way? My understanding is that Subsurface is supposed to control the master radius, and that the indivicial channels under radius control the RGB valuse of radius. Am I mistaken?
EdIt: from the Blender docs:
Rather than being a simple mix between Diffuse and Subsurface Scattering, it acts as a multiplier for the Subsurface Radius.
So maybe it's mixing and multiplying? That seems odd, but I guess I might have just answered my own question? Still interested in any insight you all can provide.
333 x 161 - 15K
Post edited by SadRobot on July 2022
  • PadonePadone Posts: 4,055
    July 2022
    You got it those values are to mimic iray.
    Specifically, the subsurface value is the mixer between diffuse and translucency, while the radius tries to mimic some volume effect. As for what's a "common setup" in blender, I would go with a high sss and a low radius anyway, rather than the contrary, because this mimics better a real material. That is, the radius is the distance the light travels for scattering, that's usually some millimeters.
  • SadRobotSadRobot Posts: 116
    July 2022
    Fascinating. Thank you! Most of the SSS shaders I've seen, and most of the ones I've made, seem to get this wrong and Subsurface quite low.
    It is not "wrong" per se. But given that you need to use subsurface as the mixer with the diffuse color, then makes sense to fit the radius, rather than the opposite. I'm including a simple scene that you can use to experiment and see the different results. Please note that it is important to use real world measures so I scaled down suzanne.
    You may like to also compare cycles and eevee and see the difference.
    zip
    zip
    sss.zip
    139K
    640 x 360 - 16K
    Post edited by Padone on July 2022
    July 2022
    Just wanted to say that this knowledge has resolved a lot of issues for me. I would end up setting the radius too high because I wasn't getting enough of an effect, but then that would result in artifacts and other issues. Your insight here has been a life saver. Thank you so much! You may want to do a blog post on this, because Blender's documentation is not great and pretty unclear.
    As one final quesiton, I'm thinking that to get the skin looking more pale, I should lower the gamma on the subsurface color node, is that correct (or at least a correct enough approach)? If so, you may want to toss that slider into Diffeo material settings somewhere if it isn't already there and I'm just having a hard time finding it.
  • wolf359wolf359 Posts: 3,940
    July 2022
    HI if the” Daz translucent “node value is set too high (for EEVEE), it Darkens/reddens the skin
    I explain how to adjust  the node in this video
    July 2022
    LOL the crying baby is funny. laughlaugh
    As for the technical side, the bsdf option is not designed for eevee, though it allows to be "adapted" for eevee via the translucent group as you show in the video. Then you can change the fac or the sss settings as you wish to fit eevee. Changing the sss gamma is also a way to adjust the skin tone but may not work depending on the sss texture. With the fac you mix between the diffuse texture and the sss texture so fac = 0 is diffuse and fac = 1 is sss.
    But, to render with eevee, personally I'd go importing with the principled option for materials that's designed for eevee and much easier to edit.
    As a side note you can use the material editor to modify multiple materials at once.
    https://diffeomorphic.blogspot.com/p/materials-section-version-16.html
  • inmymoonsuitinmymoonsuit Posts: 37
    August 2023 edited August 2023
    Hi, Padone!
    I hadn't used the Diffeomorphic importer as a primary tool in the past (only to solve some things I couldn't do other ways) but I am working on a project now and used it from the start with no other exporting / converting tools, and I've found it's amazing. Sadly for the devs/offical implementation, I find it to be superior to the official bridge!
    However, I did run into this issue with the skin seeming to be too dark. In the past, I built skin shaders much as the original poster here describes being typical in Blender.
    I wasn't sure how to solve this, and so I literally took the default Diffeo BSDF setup and mixed it with the sort of shader I'd typically build in Blender using a mix shader. The results were surpirising really nice. I'm not completely sure why, or how this could be better accomplished, but I'll attach a WIP here in case this result seems compelling to others besides me, especially if it's something worth investigating how to replicate.
    In the render below, you can see how dark the Diffeo result was:
    Post edited by inmymoonsuit on August 2023
    August 2023
    Well, the BSDF option in diffeomorphic is not designed to be "nice", nor is the best shader you can have in blender, the purpose is different. We want BSDF to convert iray as best as possible, given the same lights and a similar tone mapping, the materials should look similar.
    It is of course possible to get better and more realistic materials in cycles, but this is not the purpose of the diffeomorphic importer.
    August 2023
    I see. This makes sense! I think it does a really good job of that, too.
    Well, perhaps if anyone else finds the Iray-converted result that Diffeo does very well to be a bit dark in a more Cycles-centric project, this can be a pretty straightforward and simple solution -- to just combine it literally 50/50 with a really conventional principled setup much as the OP here describes.
    (I should also mention that my Cycles render uses an ACES config and some AO trickery.)
    Thanks for all the work you guys have done to develop and support Diffeo, by the way! :)
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
