product missing
Hi All, i have come across this product https://www.daz3d.com/inside-lindays-daz-studio-iray-scenes, I have gone through the list of required products, but cannot find the ground with water in some scene show renders, does anyone know what product the ground is from. I have checked the hdi enviroment and its not part of the ground in that product
1648 x 921 - 3M
  • WebsoulWebsoul Posts: 221
    I have never seen such a long list of requirements... Not sure if I should be impressed or terrified
    I am guessing that the ground is actually in the pack instead of a required package:
    Textures Include
    • 60 Diffuse, Height, Roughness, Normal, Opacity and Displacement Maps (4096 x 4096)
  • LinwellyLinwelly Posts: 6,070
    it might be a terrain with a water plane added but I didn't find the terrain listed in the products either, looked through the HDRI product listed as well and no, thesky and distant mountains are likely from one of those but the ground is not
  • Thanks  Both , I stills erching for what that ground could be, I have also notice differents gorunds are used in the rednder scenes, I cannot seem to find any of them at all.
  • FirstBastionFirstBastion Posts: 8,093
    I had asked the similar question in the Daz gallery a month ago and was told that the ground is an actual unlisted terrain prop included in the Linday package. But I was asking about this image.
  • Thank you, Did you purchase the product? and was the ground plain included ?  thank you.
  • I take it that we could use the camear's and the ground plain without purchasing all the other products from what I read in the nots of the product. ?
    Not yet,  though it is wishlisted. But those 60 textures mentioned by websoul above, are being used in the set in some way.
  • Thank you, teatering on the brink of purchasing.
  • AndrewJJPAndrewJJP Posts: 780
    edited June 2022
    I am guessing that with that requirements list, the market for this product is somewhat limited!
    Do you have a lot of it, I'm really impressed if you are even close to having that lot!
    Post edited by AndrewJJP on
  • barbultbarbult Posts: 27,675
    You don't have to own all those "required" products, unless you want to render every scene exactly like Linday rendered it. Substitute your own library items for what you are missing. That is what I did. Use different characters, clothes, and props. And yes, the ground planes are included in the product.
  • Thats Brilliant Thank you
