Constant Crashing
DAZ 4.8 crashes on me every time after I get a figure loaded. The figure will load, then the system crashes, Actually according to my Task Manager, the system is still running, taking up a large bit of RAM, but the interface and all images are gone. I have done both manual and Install Manager reinstalls; nothing seems to work.
Oh and this applies to both the 64 and 32 bit installations
Has this been addressed?
    What are your system specs? It works just fine for me and others so the only thing that needs addressing is what is wrong on your end.
  • IceCrMnIceCrMn Posts: 2,334
    Is this happening with a default figure with no modifications?
  • edited December 1969
    yes--Vicky 4, Michael 4 or Genesis--they all load, then the system stops
    Specs Win7 Home premium
    OS Name Microsoft Windows 7 Home Premium
    Version 6.1.7601 Service Pack 1 Build 7601
    Other OS Description Not Available
    OS Manufacturer Microsoft Corporation
    System Model p2-1117c
    System Type x64-based PC
    Processor Intel(R) Celeron(R) CPU G460 @ 1.80GHz, 1800 Mhz, 1 Core(s), 2 Logical Processor(s)
    BIOS Version/Date AMI 7.12, 5/15/2012
    SMBIOS Version 2.7
    Windows Directory C:\Windows
    System Directory C:\Windows\system32
    Boot Device \Device\HarddiskVolume1
    Locale United States
    Hardware Abstraction Layer Version = "6.1.7601.17514"
    Installed Physical Memory (RAM) 4.00 GB
    Total Physical Memory 3.89 GB
    Available Physical Memory 1.04 GB
    Total Virtual Memory 8.95 GB
    Available Virtual Memory 5.15 GB
    Page File Space 5.06 GB
    Page File C:\pagefile.sys
    I would start with a memory test to verify that you don't have a bad stick of ram (click the start button and type in mdsched.exe, then press enter.).
    Could you run Studio 4.7 without this happening?
    Did you leave the iray preview mode turned on in the viewport by chance?
    While I was an early adopter and beta tester on Daz Studio 3, I never really liked 4's interface so I didn't use it (I know, I'm a weirdo) So I TRIED 4 and 4.5 but never really used them much. But I didn't have this issue either
    It is looking more like a hardware.driver issue and not a Studio problem.
    I'm assuming, by looking at the specs you've posted that this is either a laptop or low-end desktop...probably with onboard video.
    A crash, with the GUI gone, but the process still running sounds an awful lot like an 'out of memory' problem or a video driver, especially if the video card in question is an integrated Intel 'video solution'.
    If it is onboard video, it is sharing RAM with the system, so you are starting with much less than 4 GB (don't count virtual memory, because neither Windows or Studio are very keen on being swapped to disk).
    What was open when you took that system info?
    It's showing you have 1 GB available...if that is before Studio is open, then right there is the problem...Studio itself, without anything loaded in it can take between 1/4 and 1/2 a GB...and loading any content can push much higher.
  • FishtalesFishtales Posts: 6,246
    edited June 2015
    You don't have enough memory. Windows is closing the daz windows to save memory so that it can use the memory used for the loading of the figure. If there still isn't enough memory left for graphics it wont open these windows. You can try increasing the amount of disc space used as virtual memory. The machine will be using this as the swap file which will also slow your machine away down and, depending on what you are trying to load, can take a long time. I thiNk it is time to go for a memory upgrade. Doubling your memory would help.
    Post edited by Fishtales on
    According to the specs for your machine you can take it up to 16GB max of memory using both slots.
    www.crucial.com/usa/en/compatible-upgrade-for/HP---Compaq/pavilion-p2-1117c
    I did this with my laptop so be aware it runs very hot and needs plenty of air under and around it :-)
