Brow Remover error/bug
ok in the past while it worked almost fine, now it's seens not working on almost all g8 figures, whenever i try to use the brow remover from the character i've ended with this:
1 - character before the process start:
all is normal
2 - after hit the apply brow remove buttom i'm start to get multiple errors related to "missing dxx(number).jpg file
3 then afte some errors and skips it's finally finish but it make all the face go "dark after remove the brow"
it'sa happening with lot of characters, how i can fix it?
  • felisfelis Posts: 6,547
    edited May 2022
    Are you trying on G8 or G8.1?
    Post edited by felis on
  • EllessarrEllessarr Posts: 1,395
    on g8 female
  • barbultbarbult Posts: 27,585
    I just tried it with Topsy 8 and FW Marieke HD for Charlotte 8. Both worked fine, How did you install the Brow Remover? Some scripts don't work properly if they are installed with Daz Connect (from within Daz Studio).
    1898 x 1163 - 288K
    1127 x 1247 - 197K
    884 x 1021 - 98K
    1188 x 1083 - 159K
    1205 x 1024 - 152K
    649 x 769 - 45K
    i've instaled using dim(daz instal manager)i will try to resintall it.
    edited May 2022
    ok i've resintaled it and still the same issue
    https://www.daz3d.com/maleah-for-genesis-8-female
    and the same character as you mariek hd for charlotte and got the same result, i'm doing something wrong?? what are you doing??? and you also are getting the same errors?
    https://www.daz3d.com/fw-marieke-hd-for-charlotte-8
    Post edited by Ellessarr on
    I don't get any error messages. The product has a link to Brow Remover Product Support (a commercial forum thread). Read that thread first, and post your question there if you still have problems.
    Isn't your AppData supposed to be on the C drive?
    i've changed to save everything in E: cuz it's my huge 4 tera hd, the c: is my ssd and is only for windos and those things.
    Appdata is a hidden system folder so moving it is not advisable.
