Subdivision edge weights
Is there a way to get the subdivision edge weights for a subdivision surface through the SDK?
  • Richard HaseltineRichard Haseltine Posts: 111,867
    I am told that the scripting documentation for the geometry pipeline is still being worked on, but that if you use the for x in DzWhateverObject route to get the members you can then use QMetaObject::invokeMethod() to access API members that are not in the current SDK but are script accessible. The Github FBX Importer from Daz demonstrates the application this.
  • Aha! Thank you, this is very useful information!
    There have been several updates since this exchange, with more to come, so keep checking.
  • What has been updated?
    The scripting documentation (meta-objects made available to the scripting engine, which can be called from the SDK with QMetaObject::invokeMethod()).
  • Oh, I see! Thank you!
