Glasses bundle glasses are always shades
This package: https://www.daz3d.com/glasses-bundle-for-genesis-8-and-81
The "Lens - Clear" options all still cast notable shadows on the actor's faces. When I apply Iray Uber "Glass - Thin - Clear" it's good but the lens effect is gone of course.
Product issue or just my outdoors setup?
  • Richard HaseltineRichard Haseltine Posts: 111,348
    My glasses cast shadows too - glass does not transmit 100% of the visible light.
    Have you tried any other glass shaders, "Glass - Thin - Clear" doesn't sound like one suitable for glasses.
  • richardandtracyrichardandtracy Posts: 8,029
    edited May 2022
    Could I humbly suggest trying the 'flint bottle glass' uber settings in this freebie set: https://www.daz3d.com/forums/discussion/569516/octagonal-glasses
    The glass has a IOR of 1.51 but is otherwise clear. It will show at angles other than straight on. It's nothing special, just settings I played with that look right for clear glass. If you get too much reflection, drop the IOR a bit. Anything below 1.1 doesn't show up much at all.
    Regards,
    Richard.
    Post edited by richardandtracy on
  • pixelquackpixelquack Posts: 419
    See attachment. Of course the glass isn't all clear, but that's a lot of shadows.
    955 x 668 - 2M
    As PerttiA says using one of the thin glass shaders, assuming the glasses have solid lens, will not give the correct result - it is effectively adding two layers as the thin versions are designed for cases where the glass is a single layer of polygons.
    I'm still at the question "this is casting more of a shadow than I'd think it should". What surface params can I tweak here? (And I still think it should behave different to begin with, look at the promos)
  • nemesis10nemesis10 Posts: 4,009
    edited May 2022
    I do think we must see your glasses lens settings.  I tried a very quick render using some glasses with the default iray thin glass shader, an hdri, a little eye twinkle and got:
    1540 x 1261 - 866K
    Post edited by nemesis10 on
    With the default Iray Thin Glass shader, yes. See above.
    May we have a screenshot of the glasses Surface tab settings
    Ok, here are the prop's "Lens" Surface settings.
    723 x 1045 - 105K
    454 x 1041 - 88K
    452 x 861 - 51K
