M3D Fiber Body Hair Set for Genesis 8.1 Male
in The Commons
https://www.daz3d.com/m3d-fiber-body-hair-set-for-genesis-81-male
Will this fiber hair set work on Genesis 8 males?
I'm not sure if it will load on G8M by default. There may be a way to associate it to G8, but I don't have it to test it. However, you shouldn't need it to load it on G8. If you put it on G8.1, you can then apply any of your G8 characters to G8.1 as well. G8.1 should be able to wear most all of G8's clothing also. Even though things don't really move backwards from 8.1 to 8, most things move forward from 8 to 8.1, aside from expression presets and maybe a few other odds and ends. You could try testing out applying your character(s) on G8.1, and if it works, maybe it will still be worth buying for you?
Thank you Quasar. I was thinking that hair is kind of like clothes, and G8 Clothes work on G8.1 and vice versa. I was hoping anway.
You can probably load the body hair into an empty space, change the scene identification, and then it will probably work on the old G8.
I don't know for sure because I don't own this product, but I think this should work.
More detailed instructions re scene identification here: https://www.daz3d.com/forums/discussion/comment/2981991/#Comment_2981991
I loaded a heavily morphed G8M and applied the M3D Fiber Body Hairs (all of them) to it. I did not use the Scene ID technique, instead, I let the pieces fit as unsupported. The hair morphs loaded fine and work as expected. The armpit hairs weren't visible (probably inside the torso due to the figure's extreme morphs.). That was the only issue that I saw in my brief test.
Sorry that I didn't have time to try the Scene ID technique (I normally do that when fitting items from different generations to another.)
Anyway, the product seems to work on G8M and would likely give better loading results after changing the Scene Identification (which is easy.)
Lee
Thanks so much!
