Poser Prop Morphs in Daz Studio
Hello,
let me start off by saying that this is not a new topic of discussion per se, I'm aware that this discussion exists.
However, I'm in the slightly different position that I bought my prop from a third party vendor on DeviantArt a while ago, at which time I also downloaded the free Poser trial, which I then promptly forgot. Without said morphs the prop is pretty useless.
My question is the following: is there a way to do the process outlined in the thread linked above without using Poser? While it would suck to not be able to use the prop at all, I can't justify a 100$ pricetag for a software that I don't intend to use ever again.
Thank you for your help
Post edited by Anonymous111 on
There's good news and there's bad news.
Dimension3D's Poser File Editor can resolve a .PMD into embedded deltas and save a stand-alone version of the prop - this would be usable in DAZ. The bad news is that PFE is now only available as a bundle which would cost you nearly as much as a copy of Poser so it isn't a very attractive option.
The DA vendor should be able to convert it for you - presumably they have Poser - assuming of course that they're still active.
