Iray decal node issue
Hi,
I am trying to use the Iray decal node for custom body tattoos. I managed set everyting up and it looks good. The only issue is that the projection is overlaying body parts that I don't want to be projected.
Is there a way to project only on specific part of the body? In the attached imaged you can see that the projection on the fingers that I don't want. I only want it to be on the back/side of the body.
Should I use another technique or is there a way around this?
Thanks,
Yoni
1316 x 904 - 2M
  • markusmaternmarkusmatern Posts: 618
    Render twice and combine in postprocessing?
    After the render you already have switch off the visibility of the decal, activate the spot render tool. Change its settings to "New window" and select the area of the fingers for rendering.
    Overlay the two images in an image editing program like Gimp, Affinity Photo or Photoshop and combine the two renders using masks.
  • dogcatdogcat Posts: 52
    Thanks for the tip. I'll give that a try.
    I also trying to find a non post work solution.
  • Dolce SaitoDolce Saito Posts: 197
    edited May 2022
    Try lowering "depth" of the decal. Lower it as much as possible until it starts disappearing on the skin then dial it a few clicks back.
    Post edited by Dolce Saito on
  • jmtbankjmtbank Posts: 189
    Have 2 Genesis maybe?  Hide the hand on one, and all but the hand on the other.
