Missing Textures
plaul2002plaul2002 Posts: 128
Hello,
I have a scene saved.  When I upload it I get the below missing file msg and all assets with the exception of the character are white and without testures.  When I go to the location in my C Drive there is no appdata/roaming etc.  I have uninstalled and reinstalled the assets via DIM and the Daz applicaiton.  If I load the asset seperatly even in the same scene it loads fine.  I'm trying to not have to rebuild the scene.  All the error msgs have scene optimizer in them as well for some reason.  UPDATE I was able to locate the scene optimizer folder but the temp file is 2022 not 2019?
Thanks for any help you can provide.
Example
c:/users/plaul/appdata/roaming/daz 3d/studio4/temp/v3d/sceneoptimiser/2019_11_15//runtime/textures/p3da/cpp/p3da_tvtable_base_color 2048x2048.jpg
c:/users/plaul/appdata/roaming/daz 3d/studio4/temp/v3d/sceneoptimiser/2019_11_15//runtime/textures/p3da/cpp/p3da_tvtable_normal 1024x1024.jpg
c:/users/plaul/appdata/roaming/daz 3d/studio4/temp/v3d/sceneoptimiser/2019_11_15//runtime/textures/p3da/cpp/p3da_tvtable_s 1024x1024.jpg
c:/users/plaul/appdata/roaming/daz 3d/studio4/temp/v3d/sceneoptimiser/2019_11_15//runtime/textures/z 24 hour bar/screen 1000x500.jpg
Post edited by plaul2002 on
  • Richard HaseltineRichard Haseltine Posts: 112,099
    AppData is hidden by default, but those are files created by Scene Optimiser - you need to store them in a non-temp folder (as I recall that is an option in the script dialogue, but I can't check just now) if they are to persist. You should be able to fix this if you rerun Scene Optimiser.
