Scaling issues
I am trying to make a neck area longer, however, the only option I have on the parameters are "Scale". I do not want to make it equally larger, only taller. I need the Y parameter. How do
I enable or make visible all parameters?
  • ecks201ecks201 Posts: 490
    Shaping tab > Neck Length
    I think it's a standard morph
  • digitelldigitell Posts: 598
    Thank you Ecks201 but I looked there and it is not there. Under Shape there are characters and there is only a Scale for head. I am using Genesis 2 Male.
  • MelanieLMelanieL Posts: 7,904
    Neck length is part of the G2M Body Morphs. I assume you don't have that set?
    If you want to try just changing the y-axis (it may not look good, but you can at least  try) then go to the little lines icon (aka hamburger menu) at the top of the panel and under "Preferences" select "Show hidden morphs" - this should give separate x, y and z scales.
    Melanie, Thank you!! That did it! I had no idea where to go to unhide those parameters! Many thanks!! :)
    Glad it helped smiley
    Yep! And I went ahead and bought that morph pack you kindly provided a link for. Many thanks!
