How to transfer a SBH to another figure?
Hello, so I have facial Hairs from a G3 that Id like to use on a G8 figure. As I understand it, SBH are linked to specific geometries of a figure. So I tried to create a figure prop asset from it, It worked but not perfectly, I was okay with it, but then by reloading the scene, I got a problem with the geometry because the beard appeared as a cube. I'm missing a few steps I suppose. Thank you
  • Richard HaseltineRichard Haseltine Posts: 111,371
    Is this Strand based Hair or dForce hair? Is it just hair growing from the figure, or is there a separate mesh (a "chincap", analgously with a skullcap)?
  • TheCedizTheCediz Posts: 172
    Aaa no theres no cap, just strand based hair
    The maps should be usable on Genesis 8, but I'm not sure there would be a way to transfer the styling.
    Isn't there a way to convert the SBH geometry to something like an object?
  • KainjyKainjy Posts: 913
    Export, reimport, and save as a new DAZ object .
    Try look this post for how export: https://www.daz3d.com/forums/discussion/332956/export-of-strand-based-hair-possible
    edited April 2022
    I forgot to try that. However, I wonder if the SBH surface tab can be saved as a shader preset? Someone in the tread from the link you shared said that not all UVs are preserved. I'll be trying it later anyways. Thank you! How hard can it be to create a "chincap"? Is it necessary?
    Post edited by TheCediz on
  • nemesis10nemesis10 Posts: 4,009
    There was a discussion that I think might be useful since it involves one of the most complex of the SBH uses:
    https://www.daz3d.com/forums/discussion/348066/
    edited April 2022
    Oh yeah, good tread, thank you.
    Edit: Unfortunately, I can't do it as this is for G8 to G8.
